B20/B18C5 setup?????
Old Jun 18, 2007 | 09:55 AM
urtz's Avatar
Default B20/B18C5 setup?????
i need to know what size pistons and rods to use for my Stock B20/ Stock B18C5. what kind of compression and all that stuff. im not looking to turbo it but i need something strong for vtec. please help.
Old Jun 18, 2007 | 11:40 AM
doood's Avatar
been there done that
Default Re: B20/B18C5 setup????? (urtz)
you need ls length rods if using the stock b20 crank and 84mm pistons if sticking with the stock bore
Old Jun 18, 2007 | 12:03 PM
urtz's Avatar
Default Re: B20/B18C5 setup????? (doood)
can they be stock rods and pistons?? i want to be able to redline pass the B20's redline and hit closer to type r redline. do i have to get stronger ones??
Old Jun 18, 2007 | 12:07 PM
doood's Avatar
to use stock rods and rev higher you'll need at least arp rod bolts. stock pistons wont nearly give you the compression you want.
Old Jun 18, 2007 | 12:19 PM
urtz's Avatar
i am very curious on why my stock setup failed. i was hitting vtec and the motor stopped then a whole bunch of knocking happened. i thought i blew a rod or rods. i checked and rods were fine. cylinders were clean and crank looked perfect. i change the rod bearings and piston rings. still i have a knocking noise. only when i put the plugs in???? when plugs arent in no noise. it sounds like it near the top of the block. could this be valves?? i dont have the cams installed.
Old Jun 18, 2007 | 12:20 PM
doood's Avatar
how high were you revving this stock b20vtec?
Old Jun 18, 2007 | 12:25 PM
urtz's Avatar
whatever the si cluster revs at. i think 8k
Old Jun 18, 2007 | 12:32 PM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urtz &raquo;</TD></TR><TR><TD CLASS="quote">whatever the si cluster revs at. i think 8k</TD></TR></TABLE>
that was your first mistake
Old Jun 18, 2007 | 12:35 PM
urtz's Avatar
yeah i realize that now. do the valves move though without the cams installed??? AND WHAT SHOULD I REDLINE AT if i get new rods and better pistons???
Old Jun 18, 2007 | 12:38 PM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urtz &raquo;</TD></TR><TR><TD CLASS="quote">do the valves move though without the cams installed??? </TD></TR></TABLE>
think about that for a second
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">AND WHAT SHOULD I REDLINE AT if i get new rods and better pistons???</TD></TR></TABLE>
wherever power drops off
Old Jun 18, 2007 | 12:47 PM
urtz's Avatar
but see thats the problem when the power dropped off i broke something. i dont want to break anything again. i just figured i had the stock crv oil pump and internals. the crv redlines around 6500 right. now i have a type r oil pump and possibly better and stronger rods and pistons so could i possibly rev higher and be safe. or what would be a safe redline?? do you know about the valve movement or no???
Old Jun 18, 2007 | 12:50 PM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urtz &raquo;</TD></TR><TR><TD CLASS="quote">but see thats the problem when the power dropped off i broke something. i dont want to break anything again. i just figured i had the stock crv oil pump and internals. the crv redlines around 6500 right.</TD></TR></TABLE>
exactly. revving higher than that on stock b20 internals is just asking for failure eventually.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">now i have a type r oil pump and possibly better and stronger rods and pistons so could i possibly rev higher and be safe. or what would be a safe redline?? </TD></TR></TABLE>
just so you know, all 96+ b series oil pumps are the same. how high you should rev depends on wherever the cams stop making power. the only way to know this is to put it on a dyno.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">do you know about the valve movement or no???</TD></TR></TABLE>
i'm still not sure what you're asking??
Old Jun 18, 2007 | 12:59 PM
urtz's Avatar
i am curious if do the valves move if you just have the head installed, no cams in it when u r turning the motor over? or do they only move when cams r installed and rotating
Old Jun 18, 2007 | 01:22 PM
doood's Avatar
the valves are opened and closed by the cams. so of course if cams arent installed they wont move.
Old Jun 18, 2007 | 01:37 PM
urtz's Avatar
k. just making sure. i need to know what the knocking noise is. i think its the pistons or the rods. but they look fine, the guy at the machine shop said that my piston and pins were fine too. i am soo confused on this matter, its pissing me off. it only makes noise when i start putting in the plugs 1 by 1. more compression more noise. u dont have any alternatives do you??
ribal_gh
11
Jan 17, 2013 11:10 AM
lsvtec2000
Feb 4, 2008 02:26 PM
GSRontheBottle
Texas -OK -LA (Sales)
Oct 16, 2007 08:59 AM
ek2k
Jan 25, 2005 10:35 AM
PanamaVTI
11
Feb 12, 2004 12:39 PM
