b18c5 swap help
Old Jul 13, 2005 | 03:55 PM
krskrypto23's Avatar
Default b18c5 swap help
i have a b18c5 swap with a kenji chipped p28 and am failing emissions inspections miserably... what do i need to do in order to pass? is it the ecu that's the problem or something else? my HC ppm and CO is off the charts (almost 3x the limit)
do i swap in any obd2 ecu? and does an 04 civic have a obd2 ecu?
thanks!
Old Jul 13, 2005 | 04:16 PM
Default Re: b18c5 swap help (krskrypto23)
anyone?
Old Jul 13, 2005 | 05:08 PM
mmuller's Avatar
Mad Scientist
get a chip that has closed loop enabled
Old Jul 14, 2005 | 05:11 PM
kenji's Avatar
25 Year Member
Default Re: b18c5 swap help (mmuller)
Almost all programs (custom or cookie cutter) will not pass emissions. Just clip J1 and run on the stock SOHC VTEC program and you will pass emissions.
Or you can run the stock ITR ECU and that will allow you to pass emissions.
-kenji
Old Jul 14, 2005 | 09:04 PM
moyo_rican's Avatar
Default Re: b18c5 swap help (kenji)
man this swap is gone. Its totally screwed up! Probably won't last much longer.
Hey you wanna sell it to me??
J/k
BUMP can't you just buy a sticker?
Old Jul 14, 2005 | 09:08 PM
Default Re: b18c5 swap help (JUMPTHELIGHT)
hahahha... u wish!
wat sticker?
Old Jul 15, 2005 | 06:08 AM
moyo_rican's Avatar
inspection sticker! You can't buy one where you are at? Here in jerz I can go the gas station pay 75 bucks and "BAM" here you go 2 year inspection sticker!
tatayee
39
Mar 21, 2014 09:03 PM
'00DC2
Northern California
Oct 19, 2010 06:42 PM
gurlugotmilk
Feb 6, 2009 06:29 PM
