B18c5 o2 sensor problem.. 2wires vs 4wires
I just got a b18c5 and swapped it into my db7.
They did not have the o2 sensor hooked up and here lies the problem!
The harness is for 2wires and everthing i have found is for 4wires.
What can i do?
What can i do?
Its been a while, but i think that the 2 wire is just the power send and return where as the 4 wire is power send/return and heater control.
Try searching for 02 sensor diagrams
4-wire O2 - 2-black = heater wires - 1-white = O2 signal - 1-green = O2 signal ground
2-wire O2 (which I've never seen so I'm guessing) - 1-white = O2 signal - 1-green or black = O2 signal ground
it really doesn't matter what wires are what. the key is the ECU and the O2 play well together. Which ECU are you running?
1993eghatch
Sep 24, 2010 05:52 PM
