B18C5 bottom end with B16A head
is this a good idea? anyone have any idea's of what the compression ratio might be with this set up and JDM ITR pistons? im debating between this or sleeving the bottom end and boring it out to 2.0L.
Guest
Posts: n/a
do you have a type r motor or sumthin or jus the block, cuz a type r head is pretty much a b16 head. not only that, type r head comes wit the best b-series lost motion assemblies and a better valvetrain.
i wish i had a type-r motor. i have a B16A, but i'll be rebuilding the head over the summer with skunk 2 valves, valve springs, retainer's, and stage 2 cams. thats why i want the B18C5 bottom end. i forgot to mention that if i get the C5 bottom end ill be using JDM ITR piston's that are .25mm over.
Nothing wrong with it at all, I've been running the B16 head on my B18c5 block for a while, and it's been able to pull on ITRs on the highway. (My engine is in an eg, so I weigh a ton less) but still, like has been said previously, it's the exact same head, just a little more port work done I believe, and the lost motion assemblies are better.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Btown_99Si »</TD></TR><TR><TD CLASS="quote">is this a good idea? anyone have any idea's of what the compression ratio might be with this set up and JDM ITR pistons? im debating between this or sleeving the bottom end and boring it out to 2.0L.</TD></TR></TABLE>
i just blew up this setup word to the wise dont mill the head to much if your running skunk stage 2's , otherwise i was very happy . If u already have an itr shortblock use it otherwise save yourself some $$$ and buy yourself a gsr block. I also have a legit b18c5 block 4 sale it needs to be resleeved . Ill take 200. 4 it pm me if your interested
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceboyEFsi »</TD></TR><TR><TD CLASS="quote">
I also have a legit b18c5 block 4 sale it needs to be resleeved . Ill take 200. 4 it pm me if your interested</TD></TR></TABLE>
you have mail.
you have mail.
I am pulling 186 HP with the basic bolt on's with the b16a head and the ITR block.
I have a ITR intake cam, GSR exhaust cam, ITR Valve springs and retainers, skunk2 cam gears, skunk2 intake manifold and a FPR. The head was milled 10, not sure what measurement you use, but you get the Idea.
Great Set up and less money.
Sal
Sal
hey im very interested in te b18c5 block uhave for sale email me spider69911@yahoo.com im in queens
Eddygee53
16
Jul 9, 2019 12:19 PM
i believe they are the same casting
