B18c1 vs b18c5 any differences?
Besides pistons are there any differences.. I have a choice of two blocks...one with 29K (the C1) and one with 10K (C5) the C5 is a bit more...Help me out... I don't the tech on this stuff....Thanks, Brent
from what I understand, the Type R crank is actually heavier than the GSR crank because Honda enlarged the counter balances due to the higher rpm level on the Type R. Pistons are different obviously but other than that the crank weight is the only bottom end difference I'm aware of between the B18C1 and B18C5 blocks.
The type R pistons are forged and coated from the factory, higher compression. The type R bottom end has a better rod ratio. Other than that I think they are just about the same.
Type R pistons are NOT forged... they are cast just like GSR pistons. Both are coated. The only differences are slightly "taller" pistons on the ITR to give slightly higher compression, and the crank is heavier. Rods are also slightly different, but I think the rod ratios are exactly the same.
Yes diff rods and pistons. There are also a couple more counter balancers on the ITR crank. The rod/stroke ratio is identical on both. I would get the ITR, because of the higher compression and less mileage. They are around $2000 brand new for either so base your pricing off that.
