B18C1 timing problem with Intake/Exhaust Cams
I have searched and haven't really found what I am looking for. This is my first time doing a timing belt on a DOHC motor. Sorry guys but I am pretty stumped/frustrated and lost at the moment..
I bought my B18C1 with the exhaust cam off by a tooth from TDC. I am want to reset the timing on the motor because I want to get my car tuned and verify if I have REAL SKUNK2 cams or not.
Yesterday while I was working on the car the Intake Cam slipped and right now the intake cam is completely off TDC. Now both cams are off TDC..
I wasn't really thinking so I took a 14mm wrench to the cam gear bolt and turned the INT/EX cam COUNTER CLOCKWISE to try to line up the cams at TDC. After I did this, I was able to line the EX cam TDC and then i tried the same method on the INT cam. I was able to almost line the INT cam TDC but this time the INT cam is off a tooth while the EX cam is at TDC.. It just hit me now that I may have fudged up something by doing this?
What can I do next to get the cams to sit right at TDC now?
sayanything
Dec 21, 2010 06:36 PM
