b18c1 obd 1 code
Old Jul 11, 2003 | 09:32 AM
dabomb's Avatar
Default b18c1 obd 1 code
i went to go set my timing and when i put the jumper in and started that car i was getting 7 flashes from the engine light. does anyone know what this code stands for? i cant find my god damn manual.
thanks
Old Jul 11, 2003 | 10:07 AM
Katman's Avatar
Default Re: b18c1 obd 1 code (dabomb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dabomb &raquo;</TD></TR><TR><TD CLASS="quote">i went to go set my timing and when i put the jumper in and started that car i was getting 7 flashes from the engine light. does anyone know what this code stands for? i cant find my god damn manual.
thanks</TD></TR></TABLE>
TPS sensor code.
It's the sensor on the backside of the throttlebody, if you didn't know.
Old Jul 11, 2003 | 11:42 AM
dabomb's Avatar
Default Re: b18c1 obd 1 code (Katman)
thanks man, one more question for ya i unplugged the battery for a like 10min and when i fired it up after with the jumper in there was no more code coming up, does that mean that the there wasn't really a problem or what? oh and the engine light wasn't on prior to me putting the jumper in and i'm pretty sure that if there is something wrong the engine light is supposed to light up all the time right?
Old Jul 11, 2003 | 12:29 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dabomb &raquo;</TD></TR><TR><TD CLASS="quote">thanks man, one more question for ya i unplugged the battery for a like 10min and when i fired it up after with the jumper in there was no more code coming up, does that mean that the there wasn't really a problem or what? oh and the engine light wasn't on prior to me putting the jumper in and i'm pretty sure that if there is something wrong the engine light is supposed to light up all the time right?</TD></TR></TABLE>
ok, well all you did was reset the ecu, which you should do. If the codes don't come back, your set. If there's still a problem, the check light will come back on immediatley or eventually.
zeik24
Jul 23, 2007 08:22 PM
PINKS
11
Jul 13, 2006 06:00 PM
nighttime
Jul 7, 2004 04:15 AM
Knightmare69
Sep 27, 2003 09:41 AM
Kilohead36
Aug 10, 2001 02:00 PM
