B18C1 in CRX problems
Old Jul 24, 2004 | 09:25 PM
Driven's Avatar
Default B18C1 in CRX problems
installed a OBD1 GSR in a CRX.
used a PR3 ECU and PR3 Distributor from old B16A swap.
installed skunk2 manifold, did not hook up IAB.
did not hook up O2 sensor(s).
did not install water temp sensor.
running OBDO injectors and resistor box.
car ran for maybe 3-5mins
then died... didn't stumble, just shut off.
checked for spark, no spark.
swapped ignitor pack, cap, and wires.
still no spark.
what would cause this? it would run, then just die. there IS gas in the car.
Old Jul 25, 2004 | 09:52 AM
agturbo's Avatar
Default Re: B18C1 in CRX problems (Driven)
Check if you have battery voltage from the 2pin connector ( black yellow wire ), or you might not be receiving a ignition output signal from the ECU ( assuming the wiring is good, no short/open between the ecu and the distributer (white wire)... Let me know and ill look up the pin numbers if you need it...
Old Jul 26, 2004 | 07:44 AM
Driven's Avatar
Default Re: B18C1 in CRX problems (agturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by agturbo &raquo;</TD></TR><TR><TD CLASS="quote">Check if you have battery voltage from the 2pin connector ( black yellow wire ), or you might not be receiving a ignition output signal from the ECU ( assuming the wiring is good, no short/open between the ecu and the distributer (white wire)... Let me know and ill look up the pin numbers if you need it...
I'll check it out, thanks!
Old Jul 26, 2004 | 07:53 AM
HT Chaplain's Avatar
Loved
youll have to hook up your 02 sensors like a b16a two in the headers or one if you get your ecu chipped for 1 o2 sensor, FYI i have a GSR dc sports header 4-2-1 for sale has 10k miles and i used it for your exact set up. except i chipped my pr3 to run just 1 os sensor so it just has 1 o2 bung in the header.
Old Jul 26, 2004 | 07:59 AM
Loved
Default Re: B18C1 in CRX problems (HT Chaplin)
you can splice the coolant wires onto you crx wiring harness (the 2 prong plugs in back of the crx engine) to coolant temp plug on the gsr engine
EFfin Sedan 91
Feb 8, 2014 02:48 PM
Awiechman
Mar 16, 2013 01:02 PM
IndySporty
Sep 24, 2009 06:12 PM
G0crxG0
Nov 15, 2007 11:47 AM
hondacrx90
Jun 1, 2004 06:35 AM
