B18c1 bottom with Ls Crank
ok im HEARING that you can use the ls crank in a gsr bottom. what i wanna kno is whats the gains of this. also it will be mounted with a b16 head and it will see boost.
i kno i need 2 remove the oil squirters.
please help with answer's. need asap
You can use an LS crank, and as stated above you'll need to use LS rods. The benefit is that the LS crank has a longer stroke and will give you a little more displacement compared to the GSR crank.
im doing a b18b crank in a gsr...there are several bennifits...first you gain a little stroke(displacement) second...depending on what rods you use it can change the compression ratio greatly...
ls crank with gsr rods will not clear if you have any milling done but if it is stock you will gain compression.
ls crank with ls rods is the more clearance, still lots of compression
ls crank with b16 rods not type r. low compression. usin g gsr pistons you are just under 8:1 with b16 pistons you are about 8.5:1
you might have to bend one of the oil squirters...but everything will clear
check out this site. http://www.zealautowerks.com/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rhd type r »</TD></TR><TR><TD CLASS="quote">im doing a b18b crank in a gsr...there are several bennifits...first you gain a little stroke(displacement) second...depending on what rods you use it can change the compression ratio greatly...
Wrong info!!! As everyone else here says, u can only use a ls crank with ls rods in a GSR block. I think u probably meant to say pistons instead of saying rods
Remember that it's not all instant advantages of increased displacement. LS rods weren't designed for GS-R work duty. The R/S ratio also suffers compared to a native B18C crank/rods setup.
http://hondaswap.com/engine-bu...32571/
