B18c1 and B17a cams
Old Jan 2, 2004 | 03:59 PM
80884's Avatar
Default B18c1 and B17a cams
Wondering if there is any difference in these two cams. I just bought a set of gsr cams that were suposedly out of a 95 gsr. The markings are showing me a B17a cam. I also read that this stuff is the same for both cams:
Intake lift - 10.6mm, Duration - 230 @ 1mm
Exhaust lift - 9.4mm, Duration - 227 @ 1mm
correct me if the info is not right, also tell me the difference, if any between the b18c1 and b17a cams. thanx in advance
Old Jan 2, 2004 | 04:36 PM
chad's Avatar
Moderator
Default Re: B18c1 and B17a cams (80884)
i thought b17 cams were the same as first gen b16 cams
Old Jan 2, 2004 | 04:41 PM
onePOINTsix's Avatar
Default Re: B18c1 and B17a cams (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">i thought b17 cams were the same as first gen b16 cams</TD></TR></TABLE>you are correct to my knolage, BTW are you in the Super2NRTV show?
Old Jan 2, 2004 | 05:21 PM
80884's Avatar
Default Re: B18c1 and B17a cams (Sideout)
Here is a pic of the end of the intake cam........what cam is it? Is there any other way to tell what it is other then measuring it? I really don't want 1st gen b16a spec cams
Old Jan 2, 2004 | 06:18 PM
irev210's Avatar
I can tell you thats not a 1st gen cam
Old Jan 2, 2004 | 06:22 PM
mmuller's Avatar
Mad Scientist
Well they are not 1st gen cams, they look like like b17 cams; but the the ones that 've seen dont have the most outer ring...i donno
b16a and b17 exhaust cams are the same, pri and sec. lobes on the intake are the same, but the mid lobe in the b17 is a little bigger(according to helms)
Old Jan 2, 2004 | 07:38 PM
80884's Avatar
Default Re: B18c1 and B17a cams (mmuller)
So what is the difference between B17 and B18c1 valves? I also have a set of 1990 b16a cams and these are definately different from the ones i just bought.
anyone else on how i can tell what these cams are?
si0385.
May 12, 2006 04:43 PM
GWInquisitor14
Sep 7, 2005 06:25 AM
wpgcivic
22
Feb 3, 2004 09:59 AM
SIReg9
Aug 13, 2003 03:18 PM
