B18C Idle Problem-Please Help!!
Old Sep 17, 2013 | 02:05 PM
Going JDM's Avatar
Default B18C Idle Problem-Please Help!!
Hi everyone, I have a 96 DX that Ive swapped a OBD2 B18C GSR in. It’s a pretty mild setup. It’s basically bone stock except for a few bolt ons. It has Skunk2 Pro Series 1 cams, cam gears, valve springs and retainers, HKS exhaust, ARC intake, etc.
I am running a OBD2A ECU (P72), and a Chase Bays CM1 harness. The car runs, but idles rough. It surges pretty bad and idles from 1100 to 1400 rpm when warm. I’ve cleaned the FITV (Fast Idle Thermo Valve), IAC (Idle Control Valve), adjusted the timing, adjusted the idling screw on the throttle body, made sure the harness is correctly connected, etc. The only check engine light Im getting is code 11 (99% sure). I believe this is a cooling sensor code.-No biggy
I am using an Edelbrock Victor X manifold (4760), and Im thinking that I have a vacuum leak or something is not connected. Can someone please give me direction on which lines are supposed to be connected to the back of the intake manifold? Ive searched and found little to no information.
This is what I have: (still some things to tidy up)
1. FPR
2. Plugged
3. Brake Booster
4. Plugged
5. Plugged
6. MAF Sensor
7.Plugged
8. Plugged
9. Plugged
bantum1cwa
Mar 5, 2014 06:25 AM
Going JDM
Sep 19, 2013 03:06 AM
momodc221
Aug 16, 2013 05:10 AM
leadfoot78
Sep 16, 2003 10:36 PM
user 996328629
Jun 14, 2003 10:49 AM
