B18C Block Salvageable?
Old Apr 5, 2010 | 08:44 PM
2fknlo's Avatar
Default B18C Block Salvageable?
Number 2 Piston Shattered and left the following marks on the cylinder.
Going up one oversize to 81.25mm doesn't look enough to take out the marks.
Is a engine rebuilder able to fill or do something? Or is this block goneburger???
Old Apr 5, 2010 | 09:10 PM
cibao2ner's Avatar
Default Re: B18C Block Salvageable?
try an 82mm bore..
Old Apr 5, 2010 | 10:07 PM
Psychoteen101's Avatar
You can only bore it so much, so if there are still gouges after the bore, its no saveable. You might want to weigh the differences in prices for machining compared to the price of a new block...
Old Apr 6, 2010 | 12:23 AM
2fknlo's Avatar
Now where would you source 82mm pistons? as they are not genuine.
Old Apr 6, 2010 | 12:40 AM
cibao2ner's Avatar
if u want oem cast pistons try RS machine...but for forged aftermarket cp,je,srp,wiseco i think make 82mm...
Old Apr 6, 2010 | 02:18 AM
Ruben19's Avatar
is not bad at all.
81.50mm might work but 82 would work fo sure.
PARADOX_sf
Jul 13, 2009 02:44 AM
myDC4rox
Jan 17, 2005 10:35 PM
SnOOpY-NO
Jan 12, 2005 08:09 AM
B18C4-T
Nov 24, 2002 09:30 AM
Cyber ITR
Apr 11, 2002 12:25 PM
