are B18B cams better than B18A's???
Old Aug 3, 2003 | 04:20 PM
turbohf's Avatar
Default are B18B cams better than B18A's???
i have a 90 B18A motor, and i have found someone that has some B18B cams for sale cheap. wondering if they would have a noticable improvement. btw this motor will be boosted (10psi) if that makes a diff....THANKS
Old Aug 3, 2003 | 05:52 PM
Weston's Avatar
Default Re: are B18B cams better than B18A's??? (turbohf)
The B18B makes 140hp, while the B18A makes 130hp. The blocks are the same, so the 10hp has to be due to the head, stuff connected to it (ie manifolds), and/or the ECU (if it's different). It's my understanding that it's mainly the cams, but I can't say for sure.
Old Aug 3, 2003 | 07:09 PM
RiceNmotioN's Avatar
Default Re: are B18B cams better than B18A's??? (Weston)
I doubt there's much difference. B's have a more square shaped combustion chamber than A's which gives it a better squish area. Why not just go for an aftermarket set.
92bb2
Dec 15, 2008 05:03 PM
angel_i
Jun 26, 2008 09:43 PM
stareatsun
Oct 4, 2004 05:02 AM
