B18a1 timing question
Old Mar 14, 2010 | 03:27 PM
UltimateGayness's Avatar
Default B18a1 timing question
So i just replaced the head gasket on my b18a1. I'm now in the process of putting on the timing belt. Well it's not getting any tension..new timing belt, tensioner and spring. I turn the motor over with the cams set, the timing belt gets tight and then loose...i've been ****ing with this thing for hours and cant seem to figure it out ugh. Any suggestions? thanks.
Old Mar 14, 2010 | 04:44 PM
mouab18c1's Avatar
Default Re: B18a1 timing question
Get a Helms or Chiltons book.
Old Mar 14, 2010 | 08:22 PM
i have the manual on my laptop.
Old Mar 15, 2010 | 06:13 AM
Matt93eg's Avatar
On my LS I have never had the tensionor put enough tension on the belt by simply turning the engine over a few times CCW. I usually turn the engine over to the spot where I have the most tension on the front and backside of the belt, then reach a pair of needle nose pliers in and pull on the arm of the tensionor and while pulling on it tighten the 14mm bolt.
I don't like doing it but its the only way for me to get enough tension on the belt. Just don't get it to tight because that will lead to other problems.
BTW, your screen name is disgusting..just sickening.
Old Mar 15, 2010 | 07:29 AM
i'll try that out, thanks dude
and HAHA. i know it..the name is sick. i couldnt think of anything when i signed up and it just popped in my head so i used it
Old Mar 15, 2010 | 01:13 PM
no friggin luck. are we sure hondas werent made by jews?
Old Mar 15, 2010 | 01:27 PM
kyden's Avatar
i've never had a problem tensioning the belt with stock valvetrain using the method in the helms manual.
Old Mar 15, 2010 | 02:30 PM
i got it figured it out..im retarded
Old Mar 15, 2010 | 03:18 PM
mouab18c1's Avatar
Yeap just like your Username, No Offense LOL
Old Mar 15, 2010 | 03:40 PM
none taken, I completely agree. That's why I made it hahaha
jtwoj1
Jun 5, 2015 08:24 PM
TheCrimsonGhost666
Oct 10, 2010 01:10 PM
stickyfingers
Jun 10, 2005 04:18 AM
OzWolfbane
Jan 7, 2005 05:14 PM
92KillerBee
Apr 12, 2004 01:54 PM
