b18a1 head wont seperate from block
Old Jan 3, 2014 | 10:04 PM
mrbadwrench's Avatar
Default b18a1 head wont seperate from block
I removed the 8 nuts, the 2 bolts, the cams, and there is nothing else I can see in the way. ive been pulling at it and hitting it with a hammer for a few hours now. head has started to wiggle a little bit but still absolutely no pull on it. Has arp studs if that makes a difference.
Old Jan 3, 2014 | 10:08 PM
Discosteak's Avatar
Default Re: b18a1 head wont seperate from block
intake manifold brace? also there should be 10 nuts with ARP's
Old Jan 3, 2014 | 10:12 PM
I dont see anything near the intake manifold area like a brace. Where would the extra 2 nuts be?
Old Jan 3, 2014 | 10:36 PM
Discosteak's Avatar
There should be 10 headstuds under the cams. The brace is under the intake manifold and attaches to the back of the block.
Old Jan 4, 2014 | 07:18 AM
all bolts are removed and the I'm is completely removed
Old Jan 4, 2014 | 07:30 AM
Old Jan 4, 2014 | 08:59 AM
is it possible that I have to remove the head studs? I cant see any other options.
Old Jan 4, 2014 | 01:12 PM
motoxxxman's Avatar
thats's exactly what I was just going to say. sometimes the head binds up on the studs if you can't lift it absolutely perfectly straight up, so removing the studs eliminates that issue
Corksil
Feb 2, 2011 01:21 PM
honda_student
31
Oct 9, 2007 07:49 AM
integra6650
Jul 21, 2002 05:40 PM
Reid
May 30, 2002 10:09 AM
KooK
Apr 5, 2002 08:36 PM
