b17+CTR piston redline
Old Oct 18, 2007 | 04:11 PM
Jago's Avatar
Default b17+CTR piston redline
Got a b17 running ctr pistons and new skunk2 stage 2 pro camshafts with supertech valves springs and retainers. Just wonderin what kind of revs I would be safe running
Old Oct 18, 2007 | 11:38 PM
4doorekITR's Avatar
Default Re: b17+CTR piston redline (Jago)
im planning on running the same exact setup in my b18c..Hows it run for you?.
Old Oct 19, 2007 | 06:42 PM
Jago's Avatar
Default Re: b17+CTR piston redline (4doorekITR)
good
Old Oct 21, 2007 | 12:45 PM
4doorekITR's Avatar
did u have any clearence issues,,also.Did you Degree these camshafts.I read on Skunk2s site that they recommend all pro cams to be degree'd
Old Oct 21, 2007 | 07:08 PM
Jago's Avatar
Default Re: (4doorekITR)
clearence looked ok. Put this motor together for a friend he didn't have cam gears so no adjustment could be made. The head was only resurfaced so I would only expect the cam to be retarded .5- 1.0 degree or less. Also With compression as high as it is i'm not against having a small amount of negitive timing. We don't plan on revin this motor to high just have to see how everything looks on the dyno
Old Oct 23, 2007 | 09:58 AM
4doorekITR's Avatar
im curious to see how it does on the dyno..Im still debating over the pro1 or pro 2
H22hatchin
Jun 8, 2009 06:24 PM
DA3
May 28, 2009 12:24 AM
Running925
Jan 2, 2008 09:41 PM
B18C2_sedan
Feb 17, 2005 06:28 PM
civiksi
Jun 9, 2002 09:27 AM
