B16A2 tranny/ ECU
Old Jun 28, 2007 | 11:43 AM
urtz's Avatar
Default B16A2 tranny/ ECU
i was wondering if a hyrdaulic type r tranny fits on a B16A2 motor?? can i also use a type r ecu too?? what bout wiring harness could i use a type r one too???
Old Jun 28, 2007 | 04:55 PM
urtz's Avatar
Default Re: B16A2 tranny/ ECU (urtz)
anyone know this answer????
Old Jun 28, 2007 | 06:59 PM
slowcivic2k's Avatar
Type R tranny will fit, just put it on. Why would you want to put a Type R PCM and harness in?
Old Jun 29, 2007 | 10:15 AM
urtz's Avatar
Default Re: B16A2 tranny/ ECU (slowcivic2k)
because i had a type r motor and blew it so i have the tranny,ecu,harness still. looking to get a B16A2. i found one very cheap. y what should i use
Old Jun 29, 2007 | 06:32 PM
I would use your harness and rape the Type R harness (only if its incomplete, if it is completely intact, sell it.) or another harness for clips. I would suggest staying OBD1 because you can do a lot more tuning wise than you can with a locked up OBD2 PCM, a P08/P28 would be a good choice, along with a jumper harness unless you have the tools to back PCM pins out and reorganize them in a OBD1 clip.
Transplanting a wire harness into another car is pointless to me, unless the damn car caught on fire or something. There is very little difference between a Type R harness and any other OBD2 Honda VTEC harness.....
EGHBTYPER
May 23, 2010 07:59 PM
roc_sky
Aug 4, 2009 09:08 PM
CRX_RR
28
Jul 9, 2008 04:07 PM
