B16a problem with dizzy, plz help!!
Old Aug 4, 2010 | 08:15 PM
90SxyRxy's Avatar
Default B16a problem with dizzy, plz help!!
hopefully i'm putting this thread in right place, if not sorry!
I just bought a b16a and started ripping it apart for rebuild, I noticed that one of the legs is been cut from the dizzy (what does this mean) I am doing the swap into a crx HF, is this supposed to be like this, or do i need to find a replacement. It is JDM obd0 B16a, I read that it may be a american dizzy and you have to cut a leg off, is this true? The alluminum casting is also broke were the dizzys top bolt bolts up, do i need to fix this and how to i go about that if I do....Thanks for your help.
Old Aug 4, 2010 | 09:37 PM
90SxyRxy's Avatar
Default Re: B16a problem with dizzy, plz help!!
bump
Old Aug 5, 2010 | 04:50 AM
90SxyRxy's Avatar
does anyone have any info to share?
Old Aug 5, 2010 | 11:01 AM
mouab18c1's Avatar
Someone must of had to cut it off to fit it to something else. Thats the only reason people would cut. It should still work fine. That has nothing to do with its performance.
Old Aug 10, 2010 | 08:05 PM
90SxyRxy's Avatar
thanks for the help, does anyone have the cam cap that i need, where the dizzy bolts up? i only need the one
yourpalmike
Jul 27, 2011 09:36 PM
bvillarreal
Aug 16, 2010 05:04 AM
Pworld925
Oct 14, 2008 05:58 AM
