b16a Code 8
Old Feb 1, 2010 | 02:03 PM
hondahatch91's Avatar
Default b16a Code 8
Car won't start have a crx with a b16a and it's throwing trouble code 8 which all I can find says it's a tdc sensor. Wasn't aware that obdo even used a tdc sensor, if so where would I locate it? Would it be in the distributor and what would cause it to just randomly fail? Any input would be appreciated
Old Feb 1, 2010 | 02:11 PM
mouab18c1's Avatar
Default Re: b16a Code 8
The TDC sensor is in your distributor. try another distributor to see if it resloves your problem
Old Feb 1, 2010 | 02:55 PM
Trouble code disappeared still no start though. Has Spark, Fuel, Compression, No start. All started this morning when I pulled the starter lead. Turns over just won't fire.
Old Feb 1, 2010 | 04:41 PM
Problem Solved. Was none of the above. ****ed up and shorted out msd box.
bLu92bUbbLe
Aug 22, 2010 03:02 PM
mugenbattle
Dec 13, 2003 06:12 PM
mraudio13
Sep 12, 2002 05:31 PM
H22CIVIC
Jul 2, 2001 11:19 AM
