B16A to beat B20 V-tec
Old Apr 3, 2003 | 10:48 AM
Rice Ball's Avatar
Default B16A to beat B20 V-tec
I got a stock B16A in my hatchback. My friend is having his Integra LS done. He will put B20 block with B16 head. I know he will out run me when he's done. What kind of modification should I do to prevent that. Anything beside turbo, supercharge or NOS. Thanks.
Old Apr 3, 2003 | 10:59 AM
Nameless RB26's Avatar
Default Re: B16A to beat B20 V-tec (Rice Ball)
Good luck.. without some major mods you won't come close.
Start looking into things like:
AFC.
High lift cams and a worthy valvetrain if you want to make power at higher rpm's than him.
Different intake manifold and throttle body.
A nice header.
+ lots of other things...
And definetely something in that tranny to help with that launch.. like a 4.7 or 4.9 final drive and an LSD.
Really.. good luck.
[Modified by Nameless EJ6, 12:00 PM 4/3/2003]
Old Apr 3, 2003 | 12:30 PM
V3locity's Avatar
Default Re: B16A to beat B20 V-tec (Nameless EJ6)
depends how how built it is. use you R/S ratio, buy cams and valvesprings. I'd do rods and pistons too. rev the snot out of it. If you have the money, get it sleeved to like 84mm. It's gonna be hard to do it all motor, real hard. You'll have to have a better tranny than him, hopefully he'll just have the ls tranny. Basically, you just have to do more to the engine than he does to keep up. Being a better driver will be a must.
Old Apr 4, 2003 | 10:07 AM
nsxmatt's Avatar
Depends on how much work he is having done and who is doing it. If he slaps a B16 head on a B20 block and puts it in his Teg then chances are you'll still be faster. But if it is built right then it should make some good power. But he still has a heavier teg so just go get a b20 block and do what he's doing. In a hatch you'll win
cbabyby
Aug 22, 2006 02:48 PM
ACE4DOOR
Jun 27, 2004 11:16 PM
trashkilla
May 15, 2004 12:37 PM
bseriesboosted
Oct 1, 2003 09:32 AM
daver
Apr 12, 2002 02:24 AM
