B16a/b18c1 No spark
i finished my engine sway on my 00 civic si
i installed a msd box and coil.
the car dont have any spark
i tested the ignition control module and is good. i also tested the coil and is good.
im wondering if the crankshaft position sensor had something to do with my sparks.
i had to installed the crankshaft positon sensor on my gsr block because it was an obd1 block. i had to use the b16a2 ob2 oil pump for the mountings.
i get fuel but no spark.
you think i might left a ground wire lose or out of place.
