B16 turbo overheating issue
Old Sep 13, 2011 | 05:03 PM
  #26
pcguy760's Avatar
Default Re: B16 turbo overheating issue
Originally Posted by jdmcivic2fast
that seems right i think, my boosted b18b/vtec also have overheating problems and i cant figure it out.
not to thread jack this but if i let me car idle without the fan on then it over heats, soon as i turn the fan on the temp goes to normal, when im driving with the fan on at a constant high speed like 70-80mph then my temp goes up, i have to let of the gas a little to drive at 65mph then it will be ok. Im thinking of either getting a new fan or new radiator but cant make up my mind which one to get first.
to the op, maybe try a slim fan that flows more cfm than the stock fan, see if that will help. and make sure to get a shroud for the fan too!
Maybe you should get both. I have read numerous times on here that the those Ebay dual core aluminum radiators and the slim fans work very well in boosted setups. Just and idea if you are tryin to save some money and not lose performance Hell I'm still using a del sol dual core radiator but with a nice high flow slim fan ZERO overheat no matter how I drive or what the temp is outside Goodluck man I hope u solve ur problem
Old Sep 13, 2011 | 05:05 PM
  #27
tsshaw14's Avatar
Yeah thats pretty much where im at right now i guess ill be gettin a new radiator with a stronger fan and also doing a compression check and hope its not the head gasket, should probably get a new temp sensor too
Old Sep 13, 2011 | 05:58 PM
  #28
tsshaw14's Avatar
Thanks for all the help guys i appreciate it
Old Sep 13, 2011 | 07:56 PM
  #29
jdmcivic2fast's Avatar
what about the radiator cap on those ebay radiators? Herd they arent that well made and it doesn't seal the top of radiator. Any ideas??
Old Sep 13, 2011 | 10:14 PM
  #30
civickiller's Avatar
anything thats ebay made, isnt made well
Old Sep 15, 2011 | 09:07 AM
  #31
pcguy760's Avatar
Its not made by Ebay lol and if you search on here you will see there are many high hp setups using the "ebay" intercooler or "ebay" cooling fan or "ebay" radiator with great success
Old Sep 16, 2011 | 11:23 PM
  #32
SlaminSohCivic's Avatar
Dude i had Same problem on Boost...2 Things to Do is Put your Fan on Switch and Run it all the Time&If that doesnt Keep it Cool then Take thermostate out And it will keep cool &Wit Turbo u Wont have no problem gettin heat Without Thrmo
Old Sep 17, 2011 | 01:26 AM
  #33
tsshaw14's Avatar
Well it ended up being a head gasket it was not even for a b16a2 and it was cracked, but on the plus side i did just find out this block is sleeved and confirmed it has internals so i cant complain
PaulMc
Feb 20, 2014 09:43 PM
Boost16
Jul 29, 2011 02:21 PM
mda56
Feb 19, 2011 01:44 PM
92integ_gsr
Sep 7, 2006 05:28 AM
Integra Integra
Dec 15, 2005 06:15 AM
