B16 Transplant-Whats needed?
Old Dec 19, 2006 | 06:08 AM
EkEire's Avatar
Default B16 Transplant-Whats needed?
Got offered a Good B16 for next to nothing off a friend.No gearbox. What i need to know is if i just have the engine+loom what else do i need,for example,i have an EK coupe SOHC non VTEC,D16Y7.Will the B16 just drop in straight and mate with my D16's gearbox,will i need new shafts,hubs? Will i need different engine mounts?
Any info much appreciated. Just said i'd post a thread here cos i dont have time to search with work.I could really do with the DOHC VTEC though. Thanks in advance.
Old Dec 19, 2006 | 08:28 AM
deadone000's Avatar
Default Re: B16 Transplant-Whats needed? (EkEire)
ur gonna need motormounts , hasport has some good ones...a b16 hydro tranny... axles off an integra, b16 wiring harness and ECU and u'll be good
Old Dec 20, 2006 | 12:15 PM
2mansi's Avatar
Ok as for getting the parts u will need its quite a few
1. 99-00 si motor mounts.....all of them or upgrade to hasport b series mounts in an ek
2. Some sort of b- series tranny......I would recommend b16 because of the way the 16 motor revs quickly.
3. Depending on the year ek u have a motor wiring harness....96-98 you can use an ex wiring harness and ecua nd vtec will hit fine u will just be on a diff map.....99-00 you will use an si wiring harness and ecu....if wanting to use a chipped computer you will need an jumper harness and an obd1 p28 or p72.....jumper hanness also depends on year of the car.....96-98 its obd2a and 99-00 its obd2b....
4. Axles are also needed and any b-series hydro axles will work.....
I believe that is everything and everyone please add if I am missing anything......
dth0ng69
Oct 8, 2009 09:12 PM
ahron
Jul 13, 2007 11:17 AM
LSegHatchy
Mar 18, 2006 01:07 PM
teler86
Aug 17, 2005 04:11 PM
eg360B
Feb 15, 2004 01:58 PM
