B16 TPS Setting, don't understand
Old May 11, 2004 | 01:35 PM
  #26
B16CRXT's Avatar
Default Re: (hondatechnician)
Ok two questions:
First, coul dI adjust the TPS by letting the engine get to opertaing temp. then turning the TPS one way or the other and listeng for the motot idle to reduce?
Second, when my car wouldnt start, I performed a compression test. I think I read a while back that if you dont disconnect something when you do the test, that would make your idle screwy or something.....I am thinking that is the cause of my high idle. Is this correct? How could I fix this, and what were the actual steps to the compression test?
TIA
Old May 13, 2004 | 10:50 AM
  #27
hondatechnician's Avatar
Default Re: (B16CRXT)
if u dont have a voltmeter u could adjust it by ear the car will start to idle erratic(up & down) if its off specs
Old May 13, 2004 | 12:28 PM
  #28
RNPoo7's Avatar
anybody know anything about this compression test thing?
Old May 13, 2004 | 01:46 PM
  #29
doublejz's Avatar
Default Re: (RNPoo7)
Compression test:
need a compression gauge...
take a spark plug off, place the gauge, disconect the dizzy and the tower plug of the harness on the driver side
go inside the car and get ready to crank the engine
make sure u got the gas floored completely @ WOT
crank the engine at least 4-5 times to allow compression to build
go out and read the reading on the gauge
Leakdown test
need a compressor
need the leakdown test tool and gauge
u need to make sure the engine is on TDC
then u put compressed air into the CYL #1 and once u get over 100psi in there, start to listen if u hear any leaks ( u can also do #3 before u move engine)
if u hear a leak on ur intake u have some bent valves or bad vlave seats
if u hear the leak on ur exhaust, u have bad exhaust valves or seats
if u hear the leak inside ur engine(thru oil cap) then u have bad rings
turn engine until TDC of Cyl #2 and repeat process"
-USDM 4G VTEC
giddyup21
Mar 18, 2012 06:49 PM
f20b_guy
Nov 3, 2010 11:55 AM
russ2169
Oct 24, 2009 03:55 PM
Mr_ET
Jul 3, 2008 04:02 AM
ImThatGuy
Nov 13, 2004 04:48 PM
