B16 TPS Setting, don't understand
Old Oct 23, 2003 | 05:41 PM
doublejz's Avatar
Default B16 TPS Setting, don't understand
Yes, i know at idle its suppose to be like .45v and wot like 5v but where do you measure this at? the ecu? the wires before the tps?
Old May 7, 2004 | 08:58 AM
B16CRXT's Avatar
Default Re: B16 TPS Setting, don't understand (doublejz)
Anyone know this for the OBD-0 B16? I need to test my TPS. I have a idling problem that I need to fix, but first I want to check my TPS before I replace it.
Old May 7, 2004 | 10:06 AM
StyleTEG's Avatar
you measure the middle wire in the TPS harness.
You can stick a paperclip in there, and then use the multimeter on the paperclip.
Old May 7, 2004 | 10:11 AM
SAVIOVEGA's Avatar
With the ignition ON, car not running, check the Red/Blue wire for voltage. I just cut away some of the wire insulation so that you can actually see the copper wire. Then use a voltmeter and put the positive lead on the wire, and the negative lead on a ground, like the engine block. With the throttle fully closed, it should have .5 volts, and at WOT it should be 4.5 volts. Hope this helps.
Old May 7, 2004 | 12:54 PM
doublejz's Avatar
Default Re: B16 TPS Setting, don't understand (SAVIOVEGA)
wow, someone actually brought back my 6 month old post.
Old May 7, 2004 | 02:45 PM
B16CRXT's Avatar
I would rather bring back a post that had NO replies than start a new one.
Tomorrow I am going to borrow a voltmeter and test my TPS. When you measure it for WOT do you just ope the throttle by hand and the voltage should go up, even with the car off?
Old May 7, 2004 | 03:20 PM
spaceman's Avatar
Default Re: (B16CRXT)
i think it needs to be set to electric on but not the motor running...how does a dealership adjust the tps sensor?do they have a speacial tool where you dont have to splice any wires?
Old May 7, 2004 | 04:30 PM
hondatechnician's Avatar
paper clip there three wires place one paper clip on the grn/wht wire then place another paper clip on the red/blu wire if it doesnt work try the yel/wht instead of the grn/wht
Old May 7, 2004 | 04:52 PM
B16CRXT's Avatar
Default Re: B16 TPS Setting, don't understand (hondatechnician)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondatechnician &raquo;</TD></TR><TR><TD CLASS="quote">paper clip there three wires place one paper clip on the grn/wht wire then place another paper clip on the red/blu wire if it doesnt work try the yel/wht instead of the grn/wht</TD></TR></TABLE>
How would you test two at once? Can you explain that a lil better please?
Also, I read that almost all Honda TPS are the same. Does this mean, that I can buy one from a 91 CRX and it would work with my 1st gen B16A?
TIA
Old May 7, 2004 | 06:26 PM
spaceman's Avatar
Default Re: B16 TPS Setting, don't understand (B16CRXT)
when i got my motor(jdm b16/s1/pr3)..it had a broken tps sensor/broken dis cap and a blown head gasket..so i took the tps sensor and the dis cap off of my stock crx si motor and they both work(except i need to adjust the tps and replace the head gasket too)..so how does a dealership adjust it..i may try the paper clip way,but would the paperclips change the resistance of the reading?
Old May 8, 2004 | 07:34 AM
B16CRXT's Avatar
you can adjust it? I thought you just test it, and if it isnt where it should be, you replace it? Am I wrong?
Old May 8, 2004 | 07:42 AM
spaceman's Avatar
you can adjust them..you cut a slice across the top of the rivet(looks kinda like a rivet not sure what they are called),deep enough so you can use a flathead screwdriver to take them out..then you can turn them clockwise/counterclockwise to adjust...i dont wanna have to do splicing,i wanna find out how a dealership would adjust it
Old May 8, 2004 | 02:11 PM
the voltmeter has two leads place one lead the red one (positive)to the red/blue wire via a paper clip the next lead (the black one its a ground lead) to the remaining wires vai paper clip
Old May 8, 2004 | 03:36 PM
doublejz's Avatar
if you have one that test resistance, i heard that you can just put the probes on the tps pins and measure it there.
Old May 8, 2004 | 05:24 PM
Xsi's Avatar
Xsi
http://www.integra.orcon.net.nz/tps
Old May 8, 2004 | 08:40 PM
spaceman's Avatar
Default Re: (Xsi)
thanks for the info,i guess ill do it that way...
Old May 8, 2004 | 10:39 PM
B16CRXT's Avatar
Default Re: (Xsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xsi &raquo;</TD></TR><TR><TD CLASS="quote">http://www.integra.orcon.net.nz/tps</TD></TR></TABLE>
great link Now I just need a voltmeter
Old May 8, 2004 | 10:44 PM
kur0ryu's Avatar
Default Re: (spaceman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spaceman &raquo;</TD></TR><TR><TD CLASS="quote">you can adjust them..you cut a slice across the top of the rivet(looks kinda like a rivet not sure what they are called),deep enough so you can use a flathead screwdriver to take them out..then you can turn them clockwise/counterclockwise to adjust...i dont wanna have to do splicing,i wanna find out how a dealership would adjust it</TD></TR></TABLE>
I think the older OBD0 ones had a rivet that almost had to be drilled out, the OBD1+ ones have a star bolt holding it in. on my old OBD0 B16 I had a broken tps, so I replaced it with the one off my original D16, but I had to drill the rivets out.
Old May 9, 2004 | 05:04 AM
B16CRXT's Avatar
Default Re: (kur0ryu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kur0ryu &raquo;</TD></TR><TR><TD CLASS="quote">
I think the older OBD0 ones had a rivet that almost had to be drilled out, the OBD1+ ones have a star bolt holding it in. on my old OBD0 B16 I had a broken tps, so I replaced it with the one off my original D16, but I had to drill the rivets out.</TD></TR></TABLE>
How did you get the new TPS to stay in place?
Were they pop-rivets or what? I cant see my TPS that well without taking my TB off.
Old May 9, 2004 | 06:32 AM
spaceman's Avatar
i replaced the rivets with screws with the same thread design
Old May 9, 2004 | 08:34 AM
kur0ryu's Avatar
now that I remember, my D16 TPS was held by rivets, my first gen B16 was held by screws.
Old May 9, 2004 | 03:16 PM
B16CRXT's Avatar
ok, I got in for a close look at my TPS earlier and I have those allen screws on mine. Two of them. Wednesday I should be able to get to autozone and borrow their voltmeter. I think my TPS must be bad, cuz this happened out of nowhere.
Old May 10, 2004 | 12:52 PM
if it is ur tps u need a used one. honda dealers sell tps and throttle body as one unit and the go for about 700.00 dollars
Old May 10, 2004 | 01:01 PM
spaceman's Avatar
Default Re: (hondatechnician)
ya thats true..what a scam
Old May 11, 2004 | 01:05 PM
u adjust them by loosing up the two screws holding it to the t.body have the voltmeter hooked up hold the tps and them test it by openin the throttle wide open it should read .5v if it doesnt. adjust it by move to ur right or left after that tighten the screw its easy after u while of doing hope i explain it good....... ps ur car doesnt have to be on
