b16 timing
sorry if this is a dumb question.can i ajust the cam timing buy just advancing the cams one tooth forward?i would guess this would be the sam as ajustable cam gears. thanks for you input
yes, putting the cam timing off one tooth is a big difference when compared to using adjustable cam gears. with the adjustable gears you can do 1 degree or even .5 degree increments for maximum performance without hitting the valves on the pistons (which you certainly don't want to do). if i remember correctly one tooth off is around 10 degrees difference. 10 degrees could mean valve to piston contact or would cause the engine to run horribly. so all in all it's not a good idea to try that. adjustable cam gears are the way to go.
