b16 piston change
Old May 28, 2004 | 05:46 PM
Jmorin's Avatar
Default b16 piston change
I am looking to change my pistons in my b16 and i dont really wanna bore or have clearance issues.I was wondering if this setup would work here http://www.modacar.com/product...APIS/?
Old May 29, 2004 | 04:30 PM
Jmorin's Avatar
Default Re: b16 piston change (Jmorin)
Bump please help
Old May 29, 2004 | 08:54 PM
vtecb20coupe's Avatar
B A N N E D
with any high compression piston, you will need to worry about piston to valve clearance. do a search on the boards on how to "clay a motor". also, for the price of those pistons, you can go with a as good, if not better brand for much less.
Old May 30, 2004 | 08:52 AM
dfoxengr's Avatar
Default Re: b16 piston change (vtecb20coupe)
dont buy into that mainstream toda crap. do some research and im sure you can save a ton.
Old May 30, 2004 | 03:43 PM
Jmorin's Avatar
Default Re: b16 piston change (hybridvteceg)
thanks for the help
Old May 31, 2004 | 03:55 PM
Jmorin's Avatar
ok but is there a kit i can get and just put them in there where i dont need to get it bored out? so is there a kit that retains stock size?
Old Jun 1, 2004 | 05:10 PM
Jmorin's Avatar
Anyone?
Old Jun 1, 2004 | 05:18 PM
dfoxengr's Avatar
you dont need a "kit" when you go to buy whatever pistons you buy just get rings from whoever is sellng them to you. thats all a kit is.
Old Jun 1, 2004 | 10:30 PM
3rdGteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jmorin &raquo;</TD></TR><TR><TD CLASS="quote">ok but is there a kit i can get and just put them in there where i dont need to get it bored out? so is there a kit that retains stock size?</TD></TR></TABLE>This all depends upon the condition of your cylinders. The only way to find out for sure is when you measure each cylinder out to see if your out-of-roundness and taper is still within limits. If they are, you may use the stock 81mm piston/rings of your choice (there are many manufacturers who make 81mm; a little search does wonders). Good luck on your project
Old Jun 3, 2004 | 05:36 PM
Jmorin's Avatar
Default Re: b16 piston change (3rdGteg)
Thanks that helped me alot
TylerLorenz
Feb 26, 2010 06:48 PM
v8killaz
11
Dec 26, 2009 11:55 PM
tougel
Nov 3, 2008 05:59 AM
Goldfingiz
Feb 24, 2003 09:00 PM
wreckedLS
Sep 12, 2002 06:52 AM
