b16 piston change
I am looking to change my pistons in my b16 and i dont really wanna bore or have clearance issues.I was wondering if this setup would work here http://www.modacar.com/product...APIS/?
with any high compression piston, you will need to worry about piston to valve clearance. do a search on the boards on how to "clay a motor". also, for the price of those pistons, you can go with a as good, if not better brand for much less.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jmorin »</TD></TR><TR><TD CLASS="quote">ok but is there a kit i can get and just put them in there where i dont need to get it bored out? so is there a kit that retains stock size?</TD></TR></TABLE>This all depends upon the condition of your cylinders. The only way to find out for sure is when you measure each cylinder out to see if your out-of-roundness and taper is still within limits. If they are, you may use the stock 81mm piston/rings of your choice (there are many manufacturers who make 81mm; a little search does wonders). Good luck on your project
TylerLorenz
Feb 26, 2010 06:48 PM
v8killaz
11
Dec 26, 2009 11:55 PM
