b16 main bearing clearance
we are putting eagle crank in b16 block with acl bearings... ive been searching on bearing clearances and ive found several people have said different things.. i was just wondering the actual truth.. the motor is being built for boost app.. any input would be appreciated.. thanks
Standard- S
Service Limit- SL
Endplay:
S: 0.004- 0.014"
SL: 0.018" max
Main Bearing Journals:
Diameter: #1,2,4,5: 2.1644- 2.1654"
#3: 2.1642- 2.1651"
Taper: 0.0004" max
Out of Round: 0.0004" max
Runout: 0.002" max
Main Bearing Oil Clearance:
#1,2,4,5: S: 0.0009- 0.0017"
SL: 0.002" max
#3: S: 0.0012- 0.0019"
SL: 0.0024" max
Service Limit- SL
Endplay:
S: 0.004- 0.014"
SL: 0.018" max
#3: 2.1642- 2.1651"
Taper: 0.0004" max
Runout: 0.002" max
SL: 0.002" max
SL: 0.0024" max
