B16 Engine Acl pistonrod bearing
Hello,
I have search the Honda-tech forum for hours but did not found my answer.
My pistonrod bearing sprung an now i have a pistonrod knock sound.
I want to replace the pistonrod bearings with the ACL standard.
I know that the coming in one size.
Can i replace the worn with the Acl bearings simple?
I read about the Honda bearings the come in color so these are different clearance size.
Why Honda have special clearance for the pistonrod bearings and Acl has one size and reading on the Tech forum that the Acl bearings doing great.
you can use acl its all the same **** im currently rebuilding my ls vtec and im using acl rod and main bearing BUT if you spun a bearing go get that crank inspected and machine it because if you dont it will keep spinning bearings and my personal opinion with having a crank machined on the rod journal is bad because my crank snapped in to while driving due to that so its garbage i went and bought a new standar crank ...so becareful
acrocat
Jun 15, 2007 06:34 AM
TheSwift1
Nov 12, 2002 08:12 AM
