B16 Compression test results
Old Nov 4, 2003 | 12:16 PM
doublejz's Avatar
Default B16 Compression test results
Ok so, I thought I had a bent valve so I decided to do a compression test instead of ripping the head off to find out. I got 1= 221 2=220 3=220 4=220 so I am assuming that those numbers are good. (I'm not sure what I should have got.) So I was thinking it is my LMA making the noise but I also heard that they are about bomb proof. Any other ideas what could be causing alot of noise from the valve train? I think I am going to adjust my valves soon just to see if that's the problem
Old Nov 4, 2003 | 01:58 PM
RCautoworks's Avatar
Default Re: B16 Compression test results (doublejz)
Good numbers. Sounds like your lma's are going, does it go away in high rpm's ?
Old Nov 4, 2003 | 04:09 PM
doublejz's Avatar
Default Re: B16 Compression test results (90blackcrx)
dunno, kinda hard to hear over exhaust.
doublejz's Avatar
damnit, just thought of something, when i did my compression test, i didn't do it at WOT i just left the throttle as it was. Would that drop or raise my numbers?
civic-one
Apr 6, 2011 08:02 AM
MilFhunter001
May 13, 2010 08:29 AM
The Dirty EJ1
Jun 30, 2008 12:37 AM
johnzm
Jul 26, 2004 07:46 AM
Nate B
Jun 21, 2003 03:45 PM
