B16 cams, GS-R head, HELP!
Old Sep 23, 2009 | 04:00 PM
em1pusha99's Avatar
Default B16 cams, GS-R head, HELP!
yeah i got a head from a shop that told me obd1 b16 cams are the same spec as later model B18C1 cams, is this true? i don't think they are. any help would be great, i ask because the head the cams came in is a B18C1 head, thanks
Old Sep 24, 2009 | 12:05 AM
KWayRacing's Avatar
Default Re: B16 cams, GS-R head, HELP!
not the same
Old Sep 24, 2009 | 06:56 AM
em1pusha99's Avatar
How do you know? will this matter much on a ls/vtec turbo build?
Old Sep 24, 2009 | 11:00 PM
KWayRacing's Avatar
I am a Honda Master Technician with over a dozen years experience working exclusively on Hondas with extensive experience in performance modifications also. I swapped my first Honda in 1995. I have changed at least 20 sets of B16 cams for GSR cams esp. on turboed cars and have seen substantial gains on a dyno. THe GSR cams have a better design for turbocharged cars than B16 cams. Although their lift and duration are the same their intake/ exhaust opening "times" are different as well as their amounts of overlap. Camshaft design is as or more important than duration/lift specs. Although slightly simple in design thoroughly understanding the complexities of camshaft design and its effect on internal engine dynamics takes years of study. Either way good luck.
Old Sep 25, 2009 | 08:05 PM
em1pusha99's Avatar
^^ okay so your saying i should try and get some obd2 gs-r cams? thats what i was thinking the whole time, i had a feeling the shop was rippin me off. thanks a ton, you prolly saved my engine from running like ***.
Old Sep 25, 2009 | 08:55 PM
.Manny.'s Avatar
Touching My Member
it will run fine with either set of cams, it will simply make more power with the GS-R cams.
dohdoh420
Feb 13, 2007 11:30 AM
Tuahe556c
Apr 18, 2006 10:00 AM
SOHCZCHatch
Nov 10, 2004 05:45 PM
93CXDRIVER
Jul 27, 2003 06:58 PM
