b16 cam rails different?
Old Dec 16, 2008 | 10:26 AM
B18CUL8R's Avatar
Default b16 cam rails different?
are older jdm b16a camrails different from newer b16's?
i noticed the little holes on the rail that you use to lock the cams are different on my b16 than they are on another b16 i saw.
-older jdm b16
-newer usdm b16
im also curious about how you'd lock the cams on the older b16 heads. is it the same concept as the newer heads?
Old Dec 16, 2008 | 11:20 AM
DonF's Avatar
Yes, they are different. newer cams cannot use the old holes for timing.
Old Dec 16, 2008 | 02:31 PM
Bl6da9's Avatar
The older ones are also cast aluminum vs billet on the newer engines.
Not2farFromtypeR
Aug 17, 2008 09:04 PM
Hiroshima_VTi-S
Nov 1, 2006 10:52 PM
JDMCRX
Mar 9, 2002 01:47 PM
