b16 block with gsr or itr head
Old Jun 4, 2003 | 08:01 PM
salbaje's Avatar
Default b16 block with gsr or itr head
which headgasket to use for this setup b16 block with gsr head or itr head. which timing belt to use???
Old Jun 4, 2003 | 09:36 PM
MikeSarr_GSR's Avatar
Default Re: b16 block with gsr or itr head (salbaje)
B series VTEC head gaskets, timing belts are the same
Old Jun 4, 2003 | 09:44 PM
Kataku2K3's Avatar
Default Re: b16 block with gsr or itr head (MikeSarr_GSR)
All DOHC VTEC headgaskets are the same... P30 will be their part number... Timing belts are different however... With the B18C/1/5 having a 270mm deck height it takes a timing belt which is a bit longer then that of a B16A... You always want to get the T-belt that goes for the block... LS/CRVTEC's are the exception as you buy for which water pump you run... They too have 270mm decks but it all depends of if you run the nonVTEC (17 tooth) or the VTEC (22 tooth) water pump... As you can image you would not be able to stretch a nonVTEC T-belt over a B18A/B/B20B/Z/B18C/1/5 while running a VTEC water pump and vise versa... Just get a new DOHC VTEC headgasket, water pump, and B16A timing belt... Peace
B00sted Eg2
May 24, 2009 06:43 PM
EGhatch87
May 3, 2007 10:07 AM
Sloshy
May 23, 2006 07:48 AM
1SlowSi
Mar 21, 2005 05:59 PM
avividmemory
Jan 9, 2003 03:03 PM
