b16 or b18 into a Sol... need ideas.
******* hell. i lied. im not going h22. its a waste, i dont feel like cutting up my chassis just to get things like shifter cables working.... it seems like too much of a hassle, already ontop of the axles breaking and the low oil pan.
anyway-
i think im gonna go b16 or b18. for $3000... what can i do??
since this is going in either an S or SI del sol, 3000 dollars needs to include- mounts, radiator, vafc, etc. every little part.
im open to alot of ideas... b16/gsr hybrids, high compression, whatever.
TIA.
anyway-
TIA.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by torr »</TD></TR><TR><TD CLASS="quote">i would go with a b18, becuase of the torue and the option to go with an ls/vtec later.</TD></TR></TABLE>
good point but isnt the ls slower off the bat?
also, this may seem silly, but do they make a red crinklecoat valvecover for it?
i would go b18c1, that little bit of extra torque will help you in the long run because the sol is a heavier car than most people think. with a fairly simple turbo setup 300 whp is not that hard to attain. The ls/vtec is nice for the track but is kind of a handful for a daily driver. To me the b18c1 is just the best all around platform you can do almost anything with it, this is why i one in my sol.
what year? and what model s or si? the vtec motors are almost a direct drop in with the si, the s requires more wiring.
im planning on picking up an SI.. which will have all the vtec and whatnot..
so you guys reccomend a b18c1 (ls) and then either swap on a vtec head or a turbo kit down the road?
sounds good to me.
only thing.. do they make a red valve cover for the ls?
sounds good to me.
Alright first, the B18C1 is a GSR engine, not an LS engine. Second, you can get red valve covers for the LS engine off of ebay, but they say DOHC VTEC and would thus make you a ricer.
Now to the discussion at hand. For cheap speed, I'd get an LS motor (B18B1) and a turbo. For an all motor setup, I'd start with the B18C1 and go from there.
But if I were doing this, I'd just get a Del Sol VTEC which already has a B16 in it, and then go LS/VTEC.
i dont think i could pull off a ls turbo for my budget.
i think i could barely pull off a ls vtec for my budget.
i dont want to swap in a ls and call it a day though... i rather swap in a b16 and have the vtec.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grizzly Adams »</TD></TR><TR><TD CLASS="quote">For $3000 you can get an LS and be well on your way to a turbo setup. If you aren't willing to do this, then I think your best bet would be a second gen B16A.</TD></TR></TABLE>
any reccomended supporting mods for the b16?
diy itb???
its gonna be a daily driver... i like... or better yet... i love the idea of itb, but can i use a filter on each one? or what?
Modified by jbell at 4:49 AM 3/7/2004
hrm. im thinking-
b16, adjustable cam gears, performance cams, good header, and itb's
can you guys reccomend some good "bang for the buck" parts- as in cheap gears, cams and itb's that are inexpensive, but offer good performance. i know there is a middle range that isn't too expensive, and aren't pieces of crap.
as for the itb's... can i put filters on each of the pipes? i love the idea of having them on a daily driver... but dont want to risk sucking up... everything.
tpep13
27
Aug 29, 2007 10:08 PM
