B-Series TPS, are they all the same?
I got a code for TPS Voltage too high, and from probing it it reads 5V all the time, plus my ecu reader show 96.6% throttle through the whole gas pedal range, probably a broken TPS.
I was wondering if all the B series engine TPS sensors are the same? How about the H and F sensors, are those the same?
Just as a data point, I am using a TPS from a '91 Integra LS on my B16A...no complaints and works just fine. I read somewhere that all the MPFI Honda TPS are the same...anyone else care to confirm or correct me?
No personal experience (yet), but everything I've heard seems to say that most (if not all) Honda TPS's are interchangeable. The only issue lies in dremeling a slot in the screws so you can actually remove them from the TB. You're not technically supposed to be able to replace it - go to the dealer & they'll make you buy an entire throttle body assembly.
I think not.
I think not.
Br1anPham
May 31, 2009 06:23 AM
