B-Series Piston Rings?
Old Mar 29, 2005 | 01:08 AM
ef92b's Avatar
Default B-Series Piston Rings?
hello fellow posters.
am currently doing a rebuild on my second gen B16 and problem is that there are no local parts available for it really. searched and found 124 results but not find any info.
my question is:
are B18A and B18B piston rings identical with B16 ones? can i use them with PR3 standard bore pistons? rings for the B18 are locally available w/ the nearest parts store that's why.
i'm assuming that they are so i cross checked the helms manual and haynes as well and everything is identical as far as gaps and clearances are concerned. but i still need to confirm from all of you helpfull techy guys if anyone has done so before.
any help is very much appreciated. thank you
Old Mar 29, 2005 | 09:50 AM
turbo boost's Avatar
Default Re: B-Series Piston Rings? (ef92b)
yea as long as the pistons r 81mm ...all the rings r the same
Old Mar 29, 2005 | 08:58 PM
ef92b's Avatar
Default Re: B-Series Piston Rings? (snowbunny)
ya, they're stock bore at 81mm.
anyone else have ideas or actual installs?
oh well, am gonna buy one set of rings by weekend so i'll see if all match up or not
Old Mar 30, 2005 | 03:47 PM
NJIN BUILDR's Avatar
B16,B17,B18a,b,c are all interchangeable.They are all dimensionally the same.
Glenn
bptotheeng
May 16, 2008 12:47 AM
95blackEG
May 23, 2007 02:50 PM
SanoJDm
Mar 20, 2003 12:54 PM
RSvtec
Nov 15, 2002 09:23 AM
itr0045
Mar 25, 2002 09:54 AM
