B-series Crank Question
Old Sep 28, 2006 | 11:31 AM
Darksoul's Avatar
Default B-series Crank Question
I recently acquired a crank from my friend and i need to verify that is out of the motor he claims...how do i distinguish between teh b-series cranks? Also need to know how to distinguish from sohc...should i test a rod on the crank? Help please
Old Sep 28, 2006 | 08:38 PM
slomofo's Avatar
GDD Member
SOHC vs DOHC differences:
SOHC has 6 flywheel bolts, DOHC has 8.
Cranks:
Measure the strokes
B16A/B - 70.4mm
B17A - 81.7mm
B18A/B - 89mm
B18C1/C5 - 87.2mm
The only problem you'll run into is the GSR/ITR cranks, I don't know how to tell the difference, maybe someone else can shed some light cuz they look the same to me. As far as the Civic Type-R motor, i've never seen a CTR crank before and I doubt you'll come acrossed one cuz they aren't as common as other motors.
Old Sep 29, 2006 | 08:07 AM
Salsa's Avatar
Default Re: (slomofo)
the b16 crank is 77.4 not 70.4
Old Sep 29, 2006 | 12:23 PM
kndaqikEG's Avatar
Default Re: (delslo9)
type-r cranks have more counterweights than the rest.
Old Oct 4, 2006 | 12:30 PM
Darksoul's Avatar
Default Re: (kndaqikEG)
Thank you for all your help....one more thing how would i go about measuring the stroke?
Old Oct 6, 2006 | 09:27 AM
Darksoul's Avatar
Default Re: (Darksoul)
bump
92integraVTECgsr
Apr 30, 2006 10:38 AM
d16dcoe45
Dec 1, 2005 12:57 PM
kuja
Jun 8, 2005 08:05 PM
