B series Axle issues.
Old Sep 19, 2004 | 08:06 PM
Snail EK's Avatar
Default B series Axle issues.
I have a 96 honda civic with a b18b"Ls swap) two days after i swapped i snapped my left axle. Two weeks later my right axle leaked out. I changed it asap. Few months down the road both axles leaked out. Yesterday I swapped out new axles cause one went bad. Today i was under the car check it out and its busted out again.. I didn't get on it or raped her at all.. have anyone heard of this problem?
It's lowered about 2.25" its not slammed
Using all integra parts
axles\mid shalf
Wheels are balanced
Got an alignment
Mounts good
checks for bolts and etc..
please help!
Modified by Snail EK at 5:21 AM 9/20/2004
Old Sep 19, 2004 | 08:39 PM
locash's Avatar
Default Re: B series Axle issues. (Snail EK)
When you say "leaked out", I assume you mean the boots are torn? If so, you may want to either use better cv boots, or try a different store if you are using remanufactured axles..
Old Sep 19, 2004 | 09:32 PM
Slow_Em1's Avatar
is the half shaft boted to the block?...is there snap rings in the axles?
Old Sep 19, 2004 | 09:42 PM
murtnabila's Avatar
How long since alignment? Is everthing snug and tight? You check the bolt near the hub? Don't know what else to tell you...
Old Sep 20, 2004 | 12:03 AM
honda_power69's Avatar
Default Re: B series Axle issues. (murtnabila)
What year integra axles are you using for this? For the '96-up civic chassis, you need to use the '88-'91 integra axles (they're a hair shorter than the newer model). Mine did this for a while too, kept having to replace boots. You're just binding a little, or maybe a lot in your case.
Old Sep 20, 2004 | 04:40 PM
Snail EK's Avatar
Default Re: B series Axle issues. (honda_power69)
thanks i'll try it. Anyone else tried this? I jsut got an alignment two weeks ago
keepitngga1
Dec 21, 2006 05:00 PM
John.
Jul 28, 2006 10:56 AM
whitehf
Dec 7, 2004 02:08 PM
cjames235
13
Aug 22, 2003 04:50 AM
