B&M fuel pressure gauge issues.
Old Nov 20, 2004 | 08:38 PM
cjohnson_2's Avatar
Default B&M fuel pressure gauge issues.
Has anyone elese experienced a clicking type of noise comming from there gauge?
I put a steathascope (sp) on it and its definately comming from the gauge. I put it on the fuel filter and its not the problem. checked the fuel line, fuel injectors. Its for sure comming from the gauge..
Old Nov 23, 2004 | 10:07 AM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: B&M fuel pressure gauge issues. (cjohnson_2)
never heard of that.. when you put it together, did you remember to put in the spring? did you cut the hat off within the specs?
do you have a gauge also.. is it high?
Old Nov 23, 2004 | 11:59 AM
cjohnson_2's Avatar
Default Re: B&M fuel pressure gauge issues. (Built B16A)
im talking about the actual fuel pressure gauge not the regulator
Old Nov 23, 2004 | 12:25 PM
jdmcrx34's Avatar
i bought my car with a b&m fuel gauge also on the filter. im about to change the filter and wanted to know what you guys use to sill the threds because i heard thred lock ist too strong and teflon tape will clog the filter and just be a bad idea.
Old Nov 23, 2004 | 06:55 PM
RMF
Guest
Posts: n/a
Default Re: B&M fuel pressure gauge issues. (jdmcrx34)
Those B&M gauges are the biggest piles of **** I have ever seen.I put one on a allmotor car one time .And as soon as I revved it once the glass popped off.And then a couple of seconds later the needle popped off.A that has happend almost
every time one gets used.And by the way thats probably your injectors clicking.They do that you know.On a sheet metal or thin manifold They are really loud.
Old Nov 23, 2004 | 07:03 PM
Built B16A's Avatar
Default Re: B&M fuel pressure gauge issues. (RMF)
he said he used a stethiscope, so im sure he knows where the ticking is comming from, however, i have heard those gauges arn't the greatest things in the world (even though i have 2 in 2 seperate cars, and never had a problem) but you can always try a new one.. i heard the liquid filled autolink ones are the ****...
sorry i can't help, never heard of this probelm.
Old Nov 23, 2004 | 09:40 PM
cjohnson_2's Avatar
Yea, Its not my injectors. I have RC injectors they dont really click more of a humm. It sounds to be comming from the pressure gauge or possibly the fuel filter? Im gonna take the gauge off and see if the clicking goes away.
Old Nov 23, 2004 | 09:52 PM
Built B16A's Avatar
sweet.. let us know what happens..
if anything... changing the fuel filter can be justified as mainenance. :shrugs: lol
Old Nov 24, 2004 | 12:59 PM
BrokeAssWhiteboy's Avatar
my house has wheels on it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcrx34 &raquo;</TD></TR><TR><TD CLASS="quote">i bought my car with a b&m fuel gauge also on the filter. im about to change the filter and wanted to know what you guys use to sill the threds because i heard thred lock ist too strong and teflon tape will clog the filter and just be a bad idea.</TD></TR></TABLE>use teflon paste
94VTEC2TONE
Mar 2, 2011 11:37 AM
juanchoenuncrx
Apr 10, 2008 10:09 PM
X2BOARD
May 14, 2004 11:04 AM
dubster99
Aug 25, 2001 12:31 AM
