AZ Race & Machine LSD Unit
Old Jan 3, 2004 | 05:39 PM
onePOINTsix's Avatar
Default AZ Race & Machine LSD Unit
is anyone runing this? my track **** is in need of a LSD soon and i dont feel like dishing out $800+ for a Kazz or Quafle unit, and for $225 you cant beat it hears a pic
Old Jan 3, 2004 | 06:39 PM
Default Re: AZ Race & Machine LSD Unit (Sideout)
no one knows about it?
Old Jan 3, 2004 | 07:37 PM
Mohudsolo's Avatar
It looks rather like a Phantom Grip. People say anything from POS to better than sliced bread. I assume it works the same, puts spring loaded pressure on the spider gear shaft. No-one says it works as well as a "real" limited slip, some say it damages the diff. Assuming that one works, the same, it's still a crapshoot. Quaife is still warenteed forever, with any usage. The Phantom Grip may damage the diff and many report reduced function over time.
Old Jan 3, 2004 | 08:35 PM
Default Re: AZ Race & Machine LSD Unit (Mohudsolo)
oh well i guess i'll save up for some new diffs rather kill one then buy a quafle
Old Jan 3, 2004 | 08:55 PM
Mohudsolo's Avatar
With all the motor swap people, I'm guessing you can find decent transmissions and diffs fairly cheap. My understanding is it hurts the shaft, and possibly the spider gears or the case. The ring and pinion should be fine. I don't know much about the D-series transmissions. Are the diff cases interchangeable between various versions? If they are, you can probably get usable diffs from otherwise junk transmissions and ones no-one wants like the HF or other tall geared transmissions.
So long as you can do the diff setup yourself, it really is a cheap thing to try. Ask them about the Phantom Grip and see what they have to say versus it. Could be interesting.
Old Jan 3, 2004 | 08:58 PM
the only difference between diffs that i know about is the bearing sizes vary, right now I have a POS 4 speed POS tranny that i would be more then willing to take the diff out of and swap it into a Si 5spd. Not sure if the ring gear is different but if it is thats not a hard swap
Old Jan 3, 2004 | 09:51 PM
K20EG's Avatar
I used one of these last year in my 400whp turbo streetcar and i had no problems. To be completely honest with you there is a right and a wrong way to install it
the instructions say mill the gears down till you can see the etching of the numbers or writing or somethin *i dont remember exactly* ..i used my chop saw and put a nice x-hatch in it. If you just install the unit with out milling the gears down your going to have probs
Old Jan 3, 2004 | 10:24 PM
Default Re: AZ Race & Machine LSD Unit (K20EG)
thanks for the tip K20EG and your car is still pimp wish i have money to make some K20 mounts for my EF
Old Jan 4, 2004 | 01:02 AM
bigTom's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mohudsolo &raquo;</TD></TR><TR><TD CLASS="quote">With all the motor swap people, I'm guessing you can find decent transmissions and diffs fairly cheap. My understanding is it hurts the shaft, and possibly the spider gears or the case. The ring and pinion should be fine. I don't know much about the D-series transmissions. Are the diff cases interchangeable between various versions? If they are, you can probably get usable diffs from otherwise junk transmissions and ones no-one wants like the HF or other tall geared transmissions.
So long as you can do the diff setup yourself, it really is a cheap thing to try. Ask them about the Phantom Grip and see what they have to say versus it. Could be interesting.</TD></TR></TABLE>
i wouldnt think of it that way... i mean with the diffs... if the diff blows... specifically the spider gears... the pieces can fly around a ruin other stuff in the tranny (stress may) just something to keep in mind as well
Old Jan 4, 2004 | 01:09 AM
K20EG's Avatar
Default Re: AZ Race & Machine LSD Unit (ek9t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9t &raquo;</TD></TR><TR><TD CLASS="quote">
i wouldnt think of it that way... i mean with the diffs... if the diff blows... specifically the spider gears... the pieces can fly around a ruin other stuff in the tranny (stress may) just something to keep in mind as well</TD></TR></TABLE>
Thats a thin chance pieces of the spider gears will travel all the way to the gear rails you would have to seriously break somethin in the diff for that to happen
Old Jan 4, 2004 | 11:19 AM
bigTom's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K20EG &raquo;</TD></TR><TR><TD CLASS="quote">
Thats a thin chance pieces of the spider gears will travel all the way to the gear rails you would have to seriously break somethin in the diff for that to happen</TD></TR></TABLE>
oh i fully agree... thats y i stressed "may."
im the type of person who always thinks about the worst case scenario and hopes for the best... i dont like when people think nothing can happen and then all of a sudden does and more than they expected
Old Jan 4, 2004 | 11:23 AM
if it blows and destroys my first 4 gears then that more of a reason to build a ZC/Si hybrid tranny
EG6sir2seb
Jul 30, 2007 06:37 PM
CustomX113
May 20, 2007 10:24 AM
boosted_dc2
Mar 6, 2004 04:29 PM
Dan GSR
Apr 17, 2003 07:29 PM
redline201
Sep 3, 2002 05:22 AM
