Axles?
Changing the font axles are probably one of the simplest things to do . The biggest problem is getting an axles tool. Which is just a really big socket. You have to dissassemble the "A" arm from the shock b/c most CV joints will not fit through the little space that you have. Its pretty simple. I knew nothing about it when i fist changed mine.If you need detailed instructions try the Hybridgarage.com Good Luck
