Axle problem? Stabilizer bar? Don't know
Old Oct 17, 2003 | 06:32 AM
89JDMcrx's Avatar
Default Axle problem? Stabilizer bar? Don't know
Ok when I drive my car and tapped on the gas i hear a big banging noise its only on the driver side so i parked my car and check to see if anything is wrong and i don't see anything. All i know is that when my car is parked and i grab the driver side wheel it sways back and forth like the cv joint is busted (which it isn't cause its brand new). But on the passenger side it won't budge. Also when i press on the brake the whole tire seems to jerk as well. It can't be a suspension problem cause i don't see why it will ever do that.
need all help i can get thanks.
Old Oct 17, 2003 | 07:07 AM
89JDMcrx's Avatar
Default Re: Axle problem? Stabilizer bar? Don't know (97exracer)
bump
Old Oct 17, 2003 | 08:13 AM
Rtype16's Avatar
On the top of your lowr control arm for your car there is a stabilizer bar and bushing. Most likely the washer and nut which holds this in place is not there anymore or loose. Crawl under the car and check it out.
illestsilek
Suspension & Brakes
Aug 11, 2008 07:47 AM
LST2
Suspension & Brakes
Jun 5, 2006 06:21 AM
95GSRTT
Feb 22, 2005 01:51 PM
VTECRaZeR
Jan 18, 2004 01:49 AM
