Axle intermediate half shaft bolts???? Need help in installation.
Old May 4, 2007 | 05:09 AM
HONDA RR's Avatar
Default Axle intermediate half shaft bolts???? Need help in installation.
Hello guys i have a problem installing one of the axle intermediate half shaft bolts. Is there any method to put them on? I was able to install the the two bottom bolts but the one in the top or above the axle won't go in. Is there a particular method in installing them? Am i suppose to install the one above the axle first and then the two bottom ones? Any help is appreciated. This axle intermediate half shaft is for a 5spd 05 tl its similar to a b-series just a little bigger. Right now i'am running the car with only 2 bolts. Will it cause any problem if i don't have the one above the axle? These bolts are torqued at 20ft-lbs.
Old May 4, 2007 | 07:21 AM
Wes V's Avatar
Default Re: Axle intermediate half shaft bolts???? Need help in installation. (HONDA RR)
Having only the two lower bolts installed is BAD!
There is no trick to installing the bolts as long as the half shaft assembly is correct for the engine/transmission. All three holes should line up with the holes in the engine block.
I'd recommend that you pull the half shaft and then verify that there isn't a problem with the threaded holes in the block. Screw in a bolt at all three locations and verify that the threads are clean.
Then re-install the half shaft assembly and using a mirror, verify that the holes line up. You could also try sticking a screw driver in the hole to see if it's lined up.
Wes
Old May 4, 2007 | 08:15 AM
HONDA RR's Avatar
Default Re: Axle intermediate half shaft bolts???? Need help in installation. (Wes V)
^^^^^^^ Thanks i also sent you a IM.
MIGPA26
11
Feb 20, 2010 01:17 PM
GoodEyeSniper
Feb 19, 2009 02:21 PM
EGPrelude
Jun 17, 2008 07:46 AM
djSALIX
Apr 12, 2006 09:20 PM
OneScarySOHC
Jun 2, 2002 10:12 AM
