Automatic Trans Questions
Old Apr 6, 2011 | 12:05 PM
wc4ohio's Avatar
Icon2 Automatic Trans Questions
I am unfamiliar with automatic transmissions apart from how they work mechanically. There are some questions I had on my mind, and hopefully someone could help me out.
What would damage a torque converter? They seem pretty rigid and I don't see how anything could damage them other than debris in the trans fluid, but it seems like debris would first damage the pump and then the transmission would stop working.
When putting the trans in overdrive, does an overdrive gear configuration set in automatically, or only when the wheels are at cruising speed?
It seems like a computer is making decisions to shift gears. If so, does this prevent the driver from downshifting to first gear at high speeds?
Are automatic transmissions easier to rebuild compared to a manual transmission?
Are the transmission designs used by Honda similar to those of other domestic companies like Ford, GM, etc?
Can a stock torque converter typically handle twice the horsepower of the stock engine?
Thanks for any replies
Old Apr 6, 2011 | 01:19 PM
94EG8's Avatar
Seagull Management
Default Re: Automatic Trans Questions
Abuse mostly, neutral drops and reverse to drive are particularly hard on them.
The transmission upshifts through the gears as the speed increases and at a certain speed and throttle position it shifts into over drive.
No, it depends on what it is (chev TH-350s are reasonably simple to build) but generally they are significantly more complex to rebuild than a comparable manual transmission.
Nope. Honda automatics are weird, they're built more like a manual transmission with clutch packs instead of synchronizers. Most other automatic transmissions use a planetary arrangement.
No, especially not a honda, the transmissions and the torque converter mostly due to their design don't hold much more than stock power reliably. Which is one of the reasons you see so few people running them.
jgauge
Aug 24, 2011 10:06 AM
Civic_4life
Nov 25, 2009 06:08 AM
teler86
29
Oct 18, 2006 06:55 PM
alb_accord
Apr 6, 2004 01:23 PM
LordoftheAccord
Jan 14, 2002 05:08 PM
