Assistance needed: Ignition missfire issues
Old Nov 14, 2016 | 02:32 PM
Bryan Hawkins's Avatar
Default Assistance needed: Ignition missfire issues
I have a 2000 honda accord 4 cylinder 4 door lx. I have a random misfire. I have replaced plugs, wires, cap, rotor, all 4 injectors, and the fuel pressure regular. I am now at a loss. any input would be great
Old Nov 15, 2016 | 11:14 AM
fcm's Avatar
fcm
Old Fart
Default Re: Assistance needed: Ignition missfire issues
What is your fuel pressure, random misfires a normally due to a fuel issue or spark issue, as you have already replaced the injectors and FPR I would look at fuel pressure and then spark, [quality of the spark, should be bright blue], maybe a weak coil or igniter. 94
Old Nov 15, 2016 | 11:29 AM
thanks for the response , I checked and all is good. I have no power coming from injector number 2 pigtail.
Old Nov 16, 2016 | 04:45 PM
fcm's Avatar
fcm
Old Fart
Power for fuel injectors is supplied by the PGM-FI Main Relay, [injector relay] it supplies power to all injectors as long as ign. switch is on, your problem must be at the junction connector, where the one lead from fuel injector relay splits to the four injector pigtails.
Sorry not sure where that is on your Accord, but my guess is there is corrosion at that junction/plug, unplug spray contact cleaner or WD40 into both ends and plug in and unplug a few times to clean.
If that does not work you have an "open" [broken] lead to that injector. 94
eldudepapi
Apr 20, 2017 12:00 PM
afnan
Jan 5, 2014 03:57 AM
Dave_Dc2
Mar 14, 2009 09:05 PM
bambbrose
Sep 2, 2007 04:58 AM
turbod16y7vtec
Dec 5, 2004 08:39 AM
