ARP head studs, difference between LS/vtec kit, b16a and b18c...
Yesterday at the shop we compare ARP b16a studs and b18c studs
they look exactly the same
we are sure that it'S the same for LS/vtec ARP head studs kits (the kit is more expensive than GSR/b16a kit)
someone had more infos about it?
b16 and gsr head studs are not the same...try using b16 head studs in a gsr block and see what happens...if they were interchangeable they would market them as fitting both models...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX »</TD></TR><TR><TD CLASS="quote">b16 and gsr head studs are not the same...try using b16 head studs in a gsr block and see what happens...if they were interchangeable they would market them as fitting both models...</TD></TR></TABLE>
we compare ARP b16 to OEM honda GSR and the lenght is the same when installed into the block
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rod. »</TD></TR><TR><TD CLASS="quote">use the gsr for ls/vtec</TD></TR></TABLE>
same as the b20b with b16a head as ARP said on the application list?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garrett »</TD></TR><TR><TD CLASS="quote">
we compare ARP b16 to OEM honda GSR and the lenght is the same when installed into the block </TD></TR></TABLE>
You cant compair the lenght of a head stud to OEM bolts, its not the same.
do not listen to this guy...he made another post saying that he compared b16 to gsr headstuds and they were the same...THEY ARE NOT THE SAME...if they were the same why would arp advertise them seperately?
</TD></TR></TABLE>do not listen to this guy...he made another post saying that he compared b16 to gsr headstuds and they were the same...THEY ARE NOT THE SAME...if they were the same why would arp advertise them seperately?
THEY ARE NOT THE SAME.</TD></TR></TABLE>
True. The only ones that ARE the same is the GSR studs and the LS/Vtec or B20/Vtec studs. Rest are different.
projectef
20
Mar 5, 2022 08:47 PM
paulzy
May 21, 2002 12:33 PM
