ARP head studs
Old Feb 22, 2006 | 11:55 AM
b20vtech's Avatar
Default ARP head studs
can they be reuse again?
Old Feb 22, 2006 | 01:41 PM
bdavis's Avatar
Default Re: ARP head studs (b20vtech)
yes unless you torqued them to 100+ foot-lbs
Old Feb 23, 2006 | 06:47 PM
sc4dr's Avatar
Default Re: ARP head studs (bdavis)
I'd hope he torqued them to 100+ft lbs
Old Feb 23, 2006 | 07:45 PM
Scott_Tucker's Avatar
It depends. They weren't torque to yield bolts right? As long as you did not exceed the torque specified by ARP and you used the lubricant they specified on the threads when you installed them you should be fine. Inspect the threads for damage and if there is any replace the bolt. You should not use a die on the bolt as it will seriously weaken the threads. The threads on the bolts are rolled and if you cut them with a die you will create stress raisers.
eddie7978
Engine Machining & Assembly
25
Feb 22, 2018 08:19 AM
JDM_DAKiD
May 20, 2015 01:43 PM
kornerk12
13
Aug 7, 2009 02:46 PM
the.hamburglar
Feb 17, 2006 06:48 AM
B18EG6
Mar 24, 2003 07:41 AM
