ARGH What the hell =\
Old May 31, 2003 | 10:57 AM
Goldfingiz's Avatar
Default ARGH What the hell =\
I think I have a little problem. Every now and then my shifter stiffens up a hell of a lot. It starts to vibrate, and gets really hard to shift gears. Then all of the sudden it will go away. Any idea what this could be?
Also, I have a 55 shot. I just installed it, and today I was using it. To make a long story short I missed 5th gear (please don't ask ) and the tach SHOT up to redline INSTANTLY. I immediately let off, and the car is driving but is having minor (I hope) problems. The best way I can explain it is, the exhaust sounds more "bubbly" It's making a bubbly sound, mostly on acceleration. It drives fine, no loss of power or anything. I guess I'll start with a compression check. I have a feeling the head gasket may go, which is nothing major.
Any, and all help with this stuff is very much appreciated.
EDIT I've come to the conclusion that I hit 3rd gear instead of 5th. It's the only way the tach could have shot up that fast, and revved to 9. I have a stock rev limiter, so the only way it could get passed is if it was forced. I just checked my compression and it was straight accross the board. Is it possible my timing slipped?
Modified by Goldfingiz at 3:47 AM 6/1/2003
Old May 31, 2003 | 12:04 PM
msilbernagel's Avatar
Default Re: ARGH What the hell =\ (Goldfingiz)
I had one of the first model year Dodge pickups with the Cummins diesel.. and a 5 speed Getrag transmission. That tranny used light (engine oil). I went through four of them before approaching the warranty end and bailing out.
What appeared to happen was the engine had so much torque, the heat would build up and seize the close tolerence bearings (etc) in the transmission. It almost always happend during extended drives (hours), though the loads weren't necessarily high.
Your tranny sounds like it may be doing that -- your description describes what my tranny did during those times... Check the oil level in it lately? Or, perhaps you have a bearing going out. The symptoms in my tranny would go away when it cooled down.
Regarding the 'bubbly' -- suspect a bent valve. You might check clearances to start with and see what you can see.
Mark
Old May 31, 2003 | 01:38 PM
Goldfingiz's Avatar
Default Re: ARGH What the hell =\ (msilbernagel)
Thanks Mark
I just recently replaced my clutch/flywheel (last week). I can't remember exactly if it did this before then. It feels like the shifter is dragging on the ground sometimes. That's another way to explain it...
Old May 31, 2003 | 06:53 PM
Goldfingiz's Avatar
Old Jun 1, 2003 | 03:01 AM
sgT's Avatar
sgT
try changing the fluid first, if that doesnt fix it, then you need to open the trans
and figure out what exactly is wrong.
Old Jun 1, 2003 | 07:28 AM
IN VTEC's Avatar
Clutch hub has possibly popped a spring or more. Replace clutch and the clutch release and pilot bearings that don't spin freely and smoothly.
We just replaced the clutch and flywheel on his car that had the same problem. The clutch engaged really low and the pedal pressure was more like an aftermarket DSM clutch than any Honda clutch I've ever driven.
It was really hard to get the shifter into any of the gears and practically had to be forced in, and even if you could get it in gear, it would grind really bad.
In the end, the clutch had completely popped out two springs, another was on its way out, and had one broken retainer. Heat scoring and scathing on the flywheel and pressure plate with unusual clutch friction pad wear.
Old Jun 1, 2003 | 09:21 AM
Goldfingiz's Avatar
Default Re: ARGH What the hell =\ (IN VTEC)
Damnit we just did my clutch too. Maybe the Exedy failed
Old Jun 1, 2003 | 04:02 PM
Goldfingiz's Avatar
Could it be my shifter bushings? It DOES creek when I move the shifter around. Sounds like they're shot. I'm hoping maybe it has something to do with them =\
Old Jun 1, 2003 | 09:17 PM
Phaze2 Mike's Avatar
Pretty sure its timing, see as how i retared your dizzy and it went away for the most part.
Old Jun 1, 2003 | 09:39 PM
DEVIN22CBR's Avatar
I think thats the least of honda's worries
Old Jun 1, 2003 | 11:48 PM
Goldfingiz's Avatar
Default Re: ARGH What the hell =\ (BALL BAG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BALL BAG &raquo;</TD></TR><TR><TD CLASS="quote"> What appeared to happen was the engine had so much torque
I think thats the least of honda's worries </TD></TR></TABLE>
LOL I was thinking the same thing
Old Jun 1, 2003 | 11:56 PM
_Endless_'s Avatar
did your car nose-dive when you mishifted to 3rd gear?
Old Jun 2, 2003 | 12:22 AM
Goldfingiz's Avatar
Default Re: ARGH What the hell =\ (_Endless_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _Endless_ &raquo;</TD></TR><TR><TD CLASS="quote">did your car nose-dive when you mishifted to 3rd gear?</TD></TR></TABLE>
nose dive?
Old Jun 2, 2003 | 01:25 AM
_Endless_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Goldfingiz &raquo;</TD></TR><TR><TD CLASS="quote">
nose dive?</TD></TR></TABLE>
yep like when you're doing engine break. did that happen or the tach just went straight up and the car is still moving normally without slowing down or jerking?
Old Jun 2, 2003 | 06:50 AM
Goldfingiz's Avatar
I'm pretty sure the car kept moving at the same speed. I remember saying "WTF?!" then pulling it out of gear immediately...
HopelessAccord
Nov 20, 2018 07:11 PM
COREY ITR#625
Dec 24, 2001 10:40 AM
serious
May 21, 2001 03:51 PM
