Anyone have problems with FelPro gaskets?
The reason I ask is because i just bought a Fel Pro intake manifold gasket cause i couldnt get an OEM one at the time. The FelPro was very shitty in quality, thin and flimsy. The OEM one is a very firm material. Should i be okay with this?
its just a intake manifold gasket........it should be fine......
if it were a headgasket then i would be weary about using cheaper aftermarket stuff......
i use felpro valve cover, oil pan and intake gaskets all the time......no problems here.....
Kinda OT but would you change out the crank seals if it only had 3 miles on it? I broke some **** and i gotta rebuilt and the seals are practically brand new still.
Fel pro head gaskets actually seal better cuz they're not metal, but they don't handle boost very well and take forever to scrape off. I'm running the full fel pro gasket set except for the cometic head/ hondata intake manifold/str cam seal.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slomofo »</TD></TR><TR><TD CLASS="quote">Fel pro head gaskets actually seal better cuz they're not metal, but they don't handle boost very well and take forever to scrape off. I'm running the full fel pro gasket set except for the cometic head/ hondata intake manifold/str cam seal.</TD></TR></TABLE> i agree the intake felpro's are messy when removing
crxguy406
10
Aug 17, 2016 05:01 PM
emooheo
Aug 19, 2007 03:10 PM
greasemonkee
Nov 9, 2006 11:11 AM
